Dear All,
I need a Low frequency of between 25 and 100Hz pwm out of a picaxe 28x.
Normaly it can only give 4000Hz and up from the PWM outputs.
1: Is there a way to get this done without external divider components?
2: how can I collect the pwm signal inside the 28x, so that I can calculate the pulses/second in real time and show that on a display.
2a: Or if Nr 1 is not working, can I collect the pwm puls from the pwm output and divide that internaly via my picaxe program, and then output that via another output pin?
I hope someone can help me in this because i am searching the net for 3 days to find a good solution.
Thanks allot,
Willy
Thanks allot,
Willy
