Dear all,
These are good points again. Some clarification for you all, with the aim of more good feedback.
The tracking bit is nicely sorted at the mechanical level, I am lucky enough to have an aluminium fabricator as a friend. Thus I have over 400kg of solar panels able to be tilted to follow the sun at my latitude, using only my little finger to change the azimuth, elevation still needs a winch, albeit a small one.
It has been the tracking at the software level that got me thinking a bit. I had seen the photovoltaic principle Dr_Acula mentioned, and had come to the conclusion that I'd rather be more empatic than that, to avoid all the hunting issues that seem to crop up on cloudy days. This is why I went for the clock principle instead as he suggests (Rats, I thought I was the first to think of that!). So I have settled on the Picaxe 18x with an I2C slaved clock (DS307 I think it is called?), and preloaded positions in one of the I2C slaved memory chips. (Oh yes, and if I can justify it to myself, I'll also add the lcd display so that I can see what is going on.) With the help of a neat little java script I found on the web I have all of the sun position data for my latitude and longitude for a whole year, in 15 minute intervals, hence the simple principle of looking at the date and time and moving the array to the appropriate position.
The weathering issue is important, as I am only 300m from the beach, so everything cops a fair amount of salt along with the rain. To get around this I will run stainless steel bowden cables from the array into the house itself, and sense everything from there. So the pots will at least be out of the elements, although the azimuth drive motor have been in left to fend for itself. I have settled for welding the assembly in aluminium and then packing the moving bits with grease, and accepting that I might have to replace it once every couple of years. Fortunately, thanks to the aluminium fabricators nice mechanicals, the azimuth controller was able to be made from a $20 12V motor and gearbox from jaycar, along with a $5 threaded rod and about $10worth of aluminium tubing from bunnings, so that's pretty cheap to replace, the winch on the other hand looks like being at least $200 worth so I will run the cables for that into the house as well.
I had toyed with using a photosensitive diode and LED to count the number of revolutions the drive shaft made on the azimuth tracking motor and the winch, this gets around the pot problems, but I thought that the pot might be simpler, given the problems around weather proofing everything on the azimuth motor.
The code for the picaxe is running nicely at the simulation level in its component parts, I still have to combine the lot into one program and check that I can FIT the code on an 18x chip, I think it will be ok.
Now if all of this sounds a little over the top, I can admit that my delightfully tolerant wife accuses me of making things complicated from time to time, but she at least supports me while I am doing so. From an economic principle too, this whole project is crazy. The panels will be lucky to pay for themselves in ten years, though the tracking may pay for itself in a few years given we get a decent 44 cents for each kilowatt hour that we put back into the grid here in South Australia. I estimate I will get nearly 20% more out of the panels over the year with this setup.
But then, I suspect a significant number of the users of this forum, like me, do this stuff for the fun and challenge of it, NOT the economics.
