fernando_g
There are instances where a LCD display module may not be desired or required.
In that instance, one may use 7 segment LED displays, but one requires plenty of I/O pins to do it.
Even with helper circuits like the 4511 one needs 4 pins for the BCD number plus additional pins for multiplexing the digits.
Browsing the web, I found this serial LED module. Way Kool!
http://www.rentron.com/SLED-C4.htm
The only problem I see with a PICAXE is the minimum 9600 baud requirement.
