The new 1.0.4 update has just been uploaded at
www.picaxevsm.com
As many files have been updated it is necessary to download the whole setup rather than just a patch. You can then use this setup to upgrade your installation.
The updates are:
1.0.4 19.01.2009
Upgraded ISIS core to
- greatly enhance simulation speed
- reduce convergence and step errors
- improved simulation accuracy
- added hundreds of new parts
- add colour coding syntax for BASIC program
Modified models to use universal PICAXE compilers
Modified models to improve power rail modelling
Fixed issue with nap not parsing correctly
Fixed issue with hi2cout not outputting first byte
Fixed issue with 28X1 code usage report locked at 256
Fixed issue with last lookdown value not being checked
Fixed issue with stop bit polarity of serout/sertxd
Added support for PICAXE-18M
Added support for 'readoutputs' value on 28X1
Added support for 'readportc'' on 28X1
Fixed various issues with portc simulation on 28X1/40x1
Fixed compiler issue with 'on gosub' code line numbers
Fixed compiler issue with 'select case' code line numbers
Note that as 'on.gosub' and 'select case' are pseudo commands
they require more than one click on the 'step' button to
step. This is normal behaviour, because the PICAXE is
processing mutiple if/goto commands for each 'pseudo' command.
