When using the interrupts on the 08M chip, the manual just talks about polling the "inputs". Can it poll an output also and check its state? In other words, let's say pin1 is an LED (output) and pin2 is an input button (normally high). I want to set an interrupt to check to see if the LED is on (high) and if the button is pushed (low). Can I do this? I tried it and it seems to work, but the manual just talks about polling the inputs and not polling the state of an output pin. Thanks,
Mark
Mark
