I have an automotive oil pressure sensor wired into a wheatstone bridge and the bridge output feeds into a difference opamp. The op amp output I can calibrate easily to give 0-100psi = 0 - 5V out into a standard multimeter. Problem is when I connect the opamp output to the analog input on a 20M Picaxe the readings on the Picaxe LCD display are either unstable or don't reach full scale (5V) depending on what resistor arrangement I try between the opamp & 20M or what drive I put into the bridge. There is no problem with the display, it works spot on using 5V input over the range of a pot fed into the 20M.
I think the problem is the impedance matching between opamp output & the 20M input, but can't figure out where I'm going wrong. Any ideas?? Have attached basic schematic.
