Andres Rodriguez
I am not sure about connecting an IR sensor to an input pin in the 28X2 (3V) please see the attached schematic.
I completed a POV sign with the LEDs attached to the propeller of a radio controlled airplane. To determine where to start the letters I used a device (QRB1134) that contains the emmiter and detector in one piece. It worked but it is too large and heavy to be in the rotating circuit.
I decided to try a configuration where the detector is in the moving part and the IR LED is stationary. All I need it to cause an interrupt when the detector passes by the LED.
