rigidigital
I like the 08M better than the other chips but need more memory. Can anyone help me with this ?
Mike.
Mike.
And those llinks are all to threads started by rigidigital (mike) on the same subject@Mick
Is this a similar question to
http://www.picaxeforum.co.uk/showthread.php?t=7619
http://www.picaxeforum.co.uk/showthread.php?t=9944
http://www.picaxeforum.co.uk/showthread.php?t=10278
I think you'll get the same answers.
e
IMHO, the biggest bang for the buck is to optimize, optimize, optimize your code. For instance, I had a function which I tried and tried and tried to squeeze into a 14M. I just could not make it fit. So, I wound up implementing my function with a 14M an an 08M off to the side. But then, a year later, I revisited the project, and after a day's work I had re-optimized the code so that it fit entirely in just the 14M.The previous replies should answer most of your questions, and it depends on what you mean by "more memory" -
* Program memory - No, you are limited to the 256 byte maximum. You could write an interpreter program and obey instructions to do things from external non-volatile storage but speed will be slow.
I first started with picaxe in 2007, after I finished my days work on a farm in QLD, Id retire to my cottage and play with electronics. After a few months I moved on to Canberra and worked in Building construction, then I quite that and worked for Canberra Horticulture, around paliment house. At night I did CIT classes in programming. Java, VB, C#. NO eletronics, left it all with my folks. Now Im in Brisbane looking for work, will have a box full of electonics sent down to me in the next week. Thats my excuse anyway. But from now on I will search for answers rarther than just ask them!Clearly a memory thing
