BUSHBANDIT
hi
i am seeking clarification on the i2c operation on the 40X2.
i currently am using the linear technology ltc4151 to read voltages and current on an x2 DIP package on the i2c bus while running at a chip clock speed of 32mHz.
i have had this PCB cct working previously with the x1 variey but at a chip clock speed was 16mHz
i am sending the following setup and read commands on the x2 running at a chip clock speed of 32mHz.
hi2csetup i2cmaster, i2cLoadAddress, i2cslow_32, i2cbyte
hi2cin 0,(b1,b0,b3,b2,b5,b4,b6,b7)
where
Symbol i2cLoadAddress= %11001111 'I2C address of the load (output) TLC4151
but recieve only zero's in the returned registers.
Having read some of the other posts on the forum on i2c i am a little confused by the following thread.
http://www.picaxeforum.co.uk/showthread.php?t=13506&highlight=i2c
Should this command work? or
is the i2c not capable of running at 100k under the 32mhz chip frequency?
or has the i2c command functioning changed ?
cheers
Greg
where
cheers
Greg
