<preamble> just before I ask this, I have read a lot of warnings on here about interfacing with cars, and I'm very confident that what I want to do here will not effect the car while stationary or moving in any way, and if it does - it's my fault!</preamble>
Hi all,
I'm devising a circuit (in my head) that will use a PicAxe to monitor spark intensity via a pickup on the HT leads of my old car (there's not an ECU in sight, don't worry, honest).
What I'd like to know is if any of you have done anything like this, and if so what you used as a pickup? Some timing lights use a coil temporarily placed around an HT lead to get a trigger. I'm wondering if a hall-effect device might work in this way. The leads themselves are carrying 20kV pulses, so before I play about with bits of coil wrapped around a lead - and probably blow some fuses on my 'scope - I thought I'd ask if any of you have some sage advice.
In terms of speed, a PicAxe should be able to cope with 3 sparks/pulses a rev at 5500 RPM? That's... *counts* about 280 a second right?
Cheers,
Ben
Hi all,
Cheers,
Ben
