I have a requirement to control 48 incansecent bulbs.
They are 2.5v @ 300mA each.
They are to be arranged in two sets of 24.
Only one bulb from each row will ever be on at one time.
The lamp unit must be easily detacheable from the controller using as few wires/connections as possible and ideally with no silicon in it.
I have 5v and/or 12v available at the required current but would prefer to use the 5v.
The "information" is available from an I2C device and is simply read and then displayed, so the PICAXE can spend most of it's time displaying if required.
My quandry:-
If these were LEDs, I'd simply multiplex, probably using a 2803 darlington and six PNPs driven via a 1-of-8 (74HC138) all controlled by a 28X/1. That would only require 14 wires to connect.
Unfortunately, as these are incanescent, such an arrangement would require a diode in series with each bulb. This would require a second board (with connectors etc) to facilitate the 48 diodes. Wiring would be a nightmare!
Also, the extra 0.6v volt drop would mean I wouldn't have enough drive (after mux'ing) to use the 5v line.
I can just about get away with 50% duty via two trannies from 5v. (The 2803 volt drop is pushing it.)
If I drive each bulb independantly (6 off 2803 plus latches), it would be rather a lot of chips and require a 49 way capable connector. That is not acceptable.
I'm too close to this to see the chips for the bulbs.
If anyone has any suggestions on how to drive these bulbs with the above restrictions, it would be appreciated.
My quandry:-
