Can you please help me with a problem. I am running a simple program that monitors a variable voltage and then outputs the result on the AXE033. The AXE033 works in this program (unlike that program to which I have recently describe - still having issue with that)
For some reason, the readadc10 alway returns zero regardless of the voltage on the readadc pin. I have the -08M connected to a 5V supply and a seperate 15V supply as the variable voltage.
I have attached the code and the VSM model for your reference.
I have read the previous post regarding readadc on seperate rails and I don't think this is the same issue.
Please help.
regards James.
Please help.
regards James.
