This question is very elementary. I'm trying to switch on a simple linear regulator circuit using a mosfet instead of a relay. So, not knowing much about mosfets, I picked one up at Radio Shack today (IRF510, similar to the much talked about IRF530). Wired it up as shown below and it does not work.
Any ideas what I'm doing wrong? In the way I'm showing on my drawing, it does not conduct and I can't turn it on by applying the output from a picaxe (3.6 volts). If I reverse the drain and source, it conducts all the time.
Open to ideas.
Thanks
Open to ideas.
Thanks
