Can you please help me with the VSM simulator and the AXE033 module. I have developed a program for the picaxe 28X1 using the AXE033 module and serout commands. The program works fine in the programming editor but does not produce correct LCD output in the VSM software. In summary the program is for an "brush" electroplating amp-hour monitor. The user inputs the charge to be plated via a push button, and the program counts down the charge as it is plated and then opens the circuit when the charge has been deposited.
Please see the attached VSM and program file.
Can you advise on any help and point me to where I can find the version id of the VSM software? (I read somewhere on the forum that it's not under "help about").
I am running Vista.
kind regards, James.
I am running Vista.
