Hi fokes,
I am converting a score board to run from picaxe and need some assistance with hardware choice.
The scoreboard is made up of 12* 7 segment displays.
Each 7 segment display is made from globes driven by a MOC3041 Opto Isolated Triac (1 triac per segment).
The triac requires 13.8v +ve @ 20ma constant current to drive (15ma switching threshold).
All 12 segments have a single common ground.
At the moment I am considering using 13* 18 pin pics. 1 master pic outputting serial data and 12 slaves receiving the stream and picking off the required value (0 through 9) and turning on or off 7 of it's 8 outputs to drive a segment.
Problem is what transistor to use to get the required 13.8v +ve @ 20ma?
Any help would be great
