mark.duyvesteyn
i want to have a play round with hacking my rinnai continuous hot water system.
My flatmates like to have long long showers, and the power bill is suffering as a result.
My idea is that after the hot water has been running for 10 minutes to decrease the temperature to as low as it will go - about 37C at the head. Not cold, but not really enjoyable so you will get out.
I plan on wiring reed relays to emulate the pressing of the buttons on one of the controllers and using the "flame on" LED as an indicator of the shower length interfaced with an LDR.
The controller has only 2 wires connecting it to the main gasburner out side, and the voltage across these wires is 12v DC.
Would i be able to run a voltage reg off this same line to power the picaxe, or would that interfere with the signal that is going back up toward the gas burner??
any thoughts or suggestions? here something that someone has done similar. http://jon.oxer.com.au/blog/id/264
