Nicholas23
Hi everybody.I am new to electronics, and am wondering what the
differance is between GND,0v, and -volts? Any help is wanted.
Here was where we reproduce Michael's guide.... http://www.minisumo.org.uk/datasheets.phpHere's an old version, bit moth eaten and dusty -
http://www.picaxeforum.co.uk/showthread.php?t=4734
Hey, I still have one of those positive common cars from the fifties (1959 to be exact) laying around here somewhere. Came across that issue trying to install an 8-track. Dead serious. Got it to work, too. While there were 8 track tapes...... I don't know about my brother's old British cab, never asked.The Kraken Awakes....
Peter: "some older British cars" - older?!? You mean pre 70s if not older? Thats blooming ancient! The last one I remember was my Grandad's Ford Prefect and that was 50s I think.
In this case GND and -Vbat are wired to be the same. It's just a case of what one wants to do with the parts. You could connect +Vbat to GND instead, or have a second battery and connect GND to the middle join between them (Not recommended).How come on the picaxe system, where it says 0v, as in
the pinout diagram, when connected to -volts as in a battery it works fine?
??????????- in spite of damper soils here (& also being legally ALLOWED to do simple mains wiring!), NZ mains wiring practices follow Australian standards 100%,hence AS/NZS, & a dedicated electrical earthing stake (which must be accessible for inspection) has long been mandatory. Concrete dwelling floor slabs are usually thermally & moisture insulated by layers of plastic & polystyrene anyway.I do know that in New Zealand it is (or at least was) permissible to connect the earth wiring of a house to the reinforcing in the concrete floor slab and no electrical stake was required into the ground.
The standard AS/NZS 3000 covers Australian and New Zealand wiring rules. There are some (not many) clauses that apply only to one of the two countries. These are identified by the markings A or NZ against the clauses.??????????- in spite of damper soils here (& also being legally ALLOWED to do simple mains wiring!), NZ mains wiring practices follow Australian standards 100%,hence AS/NZS, & a dedicated electrical earthing stake (which must be accessible for inspection) has long been mandatory. Concrete dwelling floor slabs are usually thermally & moisture insulated by layers of plastic & polystyrene anyway.
The dwelling's galvanized water piping certainly ONCE (pre WW2 era ?) may have double dutied for earthing, & many a plumber can relate hair raising ( & tragic...) tales about this. These usually arise from a loose switchboard neutral then causing the earthing path,instead of the correct M.E.N. (Multiple Earth Neutral),to carry the return current. It's essential to use a clamped bypass bridging cable when cutting such pipes or replacing sections with non conductive plastics. Stan in EnZed
