Flow chart for servo motor
peg
Good evening
I am trying to write simple code to move servo motor to 45' 90' 180 using the flow chart.
can I do this using the servo command only or do I need to use variable as well - and if so why.
I have to say I have found the manual totally confusing.
Thanks
The bear
Try to convert to Basic as soon as possible. You will eventually.
There is not so much help for people using the Flowchart.
Once you have taken the plunge, things will become easier. (I might be a senior member, but, really a beginner at heart).
Good luck...........
peg
thanks but need to do urgently to add to project - will try phoning PICAXE - hopefully somebody at the end of the line. :)
If just jumping to 45' 90' and 180' angles you should be able to specify those using just SERVO command, setting the 'Position' to the appropriate values.
You would only need to use a variable if you were wanting to move the servo more slowly between one position and another. The variable would be used to specify the position it should be at as you progress.
peg
Thank you technical support - works perfectly using basic code - (which I was avoiding) - .
