I just bought a picaxe-08 solder less Dev kit from phanderson.com, I set it up, and got my computer to see the chip on COM1, AND I get a correct com port test, the pic was sent to me pre programmed to loop a led blink whenever I do a COM test I'll hit the green led and it will freeze the actual led on the circuit to I'm assuming that means it works as I do have a connection to the chip. So that eliminates the physical stuff, but whenever I try to run, I get a
"Error 53: File does not exist."
Then a
"The following path is invalid..."
"C:\program files\programming editor\picprog\picaxe08a.exe"
Also, whenever I try to clear hardware memory I get this...
Error - Hardware not found on COM1:
Possible causes:
1)Hardware not connected.
2)Hardware not powered.
3)Hardware contains blank microcontroller.
4)Hardware needs to be reset. To do this disconnect the battery...
...then click PICAXE>Run to start a download...
...Them reconnect the battery when the progress bar appears.
5)*** Is pin0 in the program position on boards fitted with a jumper link? ***
I'm pretty sure its software related, I'll try re-installing maybe tomorrow, untill then, any help would be appreciated!
~Rad-
Then a
Possible causes:
~Rad-
