Michael 2727
I have been getting Error codes appearing.
Using the new colour Ver, ontop of 4.1.10 App.
Error!
Error:53 file not found |
Then -
Path Error
The following path is invalid... |
c:\program files\programming editor\picprog\picaxe08a.exe |
It seems if your code is between 237 to 246 bytes long
this may occur (almost full - 08M).
If this happens you may have to backtrack up to 20 bytes
of code to get it working again, you can then build it up,
but I have not been able to cram more than 254 bytes in
before the error.
I did not seem to get this before the colour addition
I usually got the Program Full warning only.
The code I am working on at present will go down to the
wire (last byte or so), I will keep trying,,~ ;o)
The code I am using is very busy with an embedded infrain2
command, which is not causing the program to halt while
attempting to D/L the new code, as it is ticking away and blinking here
while the errors come up BTW.
PS: just found stockley's post a few down
I knew had seen it mentioned before,, I am
running XP Pro Op sys.
Edited by - Michael 2727 on 12/28/2005 6:11:34 AM
Error!
Then -
Path Error
before the error.
