NateTheGreat
Setup:
Picaxe 14M
Prolific PL2303 chipset USB to Serial Cable, latest drivers (v1.0.5.18)
Vista Service Pack 1
Picaxe Programming Editor, latest version (v5.2.7)
I am attempting to program a 14M chip using a Prolific chipset USB to Serial converter, chipset PL2303 (unsure of the manufacturer of the actual cable; it was bought from Sparkfun). I purchased this Prolific cable after seeing that most board members recommended it over other 3rd-party cables. However, during programming I receive "Serial port error - code 0x1F54 'Error reading comm device'. I searched and found 3 forum threads with the same error, none of which resolved my issue.
I have 3 wires soldered to a female DB9 connector for the interface. Pin 2 (PC Rx) goes to the 14M Serout. Pin 3 (PC Tx) goes to the 14M Serin. Pin 5 (GND) goes to the ground.
Diagnostics/troubleshooting steps so far:
If anyone has any ideas for a fix or other troubleshooting tips, any help is greatly appreciated.
Picaxe 14M
- Steady voltage of 4.99V powering the 14M, regulated with a 7805 and a couple of capacitors
- Serial port test in Programming Editor passes; voltage to SERIN is -5.55V when LED is off, +5.55V when LED is on
- Swapped 22k resistor between PC's Tx and 14M's SERIN for a 10k
- Ran Programming Editor as Administrator in Vista
- Tried exact same setup on second computer (first was Vista x64, second was Vista x86); no change
- Swapped in a second 14M in case first was bad; no change
