bruciferofbrm
As discussed in by others in another thread, I too am seeing the SERIAL set time problem in my AXE033 unit.
I put in a new DS1307, a fresh 3v Cr2032 (I checked it) and have had no luck getting it to take my set time command.
I tried WestAust55's code and get the crawling character set across the top line, but line 2 still read as 06/06/00 05:02 on the bottom line. (no clock jumper in place)
Oye, this is frustrating.
Assembly wise, all you put together on a AXE033 is you connect the LCD to the drive board, and then solder on you power and data lines.
I did put a proper jumper across the CLK position and that works as expected (ie: shows time on screen when powered up) when installed but it never increments.
The one stand out point I want to make is that I have put a link across J2 for running off of 4.5v power.
I find it odd that people have the exact same problems in SERIAL mode. How could people get this wrong every time when they each put it together separately? Why do they always get the same symptoms?
I don't blame the an board firmware. If there was a problem, I couldn't use it as a display at all. Right?
So why does SERIAL mode have a problem talking to the DS1307? Did Maxon/ Dallas Semi change something functionally over the last few year that make the chip work differently?
I guess I'll have to fall back to trying out I2C mode now. Luckily I just bought a 28X1 and am not stuck on my 28A that I bought originally with my dev board and my AXE033.
Does anyone have any new ideas to consider?
