I've canned the MAX713 battery charger and am now going with a linear design.
I have a 08M pwming a TIP35C NPN transistor, by varying the pwm rate I can controll the I going into the battery. I have a DS18B20 temp sensor encased in the battery pack. (btw battery pack heat shrink is a special product and works a lot better than common heatshrink). With this set up I can terminate fast charge on temp rise and time and delay fast charge if battery pack is under/over temp. I have it bread boarded and it all works well.
Problem is I need to be able to run the 08M via a V regulator off the same DC 13.8V supply that is charging the battery. I'm switching the low side of the battery supply with the NPN. If I try and run the picaxe of the same supply that is charging the battery then the batterys low side is always grounded by the picaxes ground.
Ive had a good look around on google for ideas of how I can get around this. I cant find anything probabaly because I dont even know what such a circuit is called. I thought there might be a commonly used soloution that someone on the forum would know of.
I learnt about H bridges and potential dividers by asking questions here in the past.
