biggmacattack
Hi... I am using an 08m to count the number times a button is pressed in a specific amount of time (more than 5X). Then depending on the amount of times the button is pressed have the chip illuminate an led. I can't seem to get this to work in the simulator.
So, is this operator error or will the simulator not count the number of inputs?
Thanks
Thanks
Main:
count 3, 5000, b1 'counts the button presses on pin3
If B1 > 5 then ledon 'reads b1 with an if/then
ledon:
High 1 'led on
pause 500
Low 1 'led off
