I have my temp differential program running nicely for my solar water collector and would like to control some fans for the rock storage system. I can turn the fans off or on easily but would like to also run the fans to the peak temp of the rock storage and then shut off and reset to a beginning temp rather than keep running and drop the storage temp.
I have seen programs that keep adding but not sure just how to go about it.
I think you would add each sensor reading and if the last reading was > than the last couple of readings then you shut the fans off and reset to basic temp setting.
Funny how talking it through helps form a solution.
