Controlling a 120V AC Motor
firestorm961
I am working on a project where I need to control a motor that runs on 120V AC, anywhere between 1-5 amps. I seem to be at a loss at finding a suitable relay, mosfet, or even photocoupler to handle this. Any suggestions on hardware to do this?
120v AC is a lethal voltage. If you are at a loss to know how to control a 120v motor, I suggest you may not be ready to work with mains voltages.
Please consider this risk to your life. The mains is not something you experiment with.
For safety reasons use a relay. There must be hundreds of suitable ones available.
How are you powering the PICAXE?
If you have 12v/24v available, then your relay choice gets even larger.
I also agree with the comments made by inglewoodpete.
firestorm961
Not so much at a loss on controlling the motor, just finding the correct hardware to not destroy a picaxe. I deal with 240V all the time at work, I'm just new to using microcontrollers.
edit: using a 9V power source, regulating it to 5V for the picaxe of course.
Andrew Cowan
You could use a triac, but I would recommend a relay. Much simpler, easier, and safer. Note tha you'll need a transistor (BC639?) between the PICAXE and relay coil.
A
firestorm961
Thanks for everyone's advice. Between what was said here, some more research, and a schematic doing very close to what I am looking for, I've got it figured out.
KMoffett
No one has mentioned SSR's (solid state relays). The input LED on these can be driven directly from a PICAXE output, some without even an external resistor. The output current rating should be doubled for an inductive loads like motors. They are frequently available on sale from MPJA for a reasonable price: http://www.mpja.com/products.asp?dept=133
Ken
gengis
KMoffett Agreed SSR's are hard to beat for rugged on-off mains switching and a safe way to do it.
One caveat: they leak, so bear that in mind. The load is usually enough to drop the voltage caused by leakage - but open circuit, or with light loads, you may see some voltage there.
You can build an SSR for lots less than a new one costs. ~$1--2 for a triac and $0.20 for a zero crossing opto isolator, last time I stocked up.
Don't sell the z-cross opto isolators short either - they can control about an amp directly, so are great for driving electromechanical relays, solenoid valves, equipment power switches, etc.
One of my stoves range controls has a picaxe controlling the heat. Costs less than the $25+ they wanted for a new electromechanical control. One DPDT relay for safety, but modulation of the heater is done by a SSR under control by a picaxe. Working like a champ for a month now - with a tricolor led flashing the power setting. I like it so much, I plan to replace the working controls with more picaxe ones. The range eats 7 amps at 240 volts. The old bimetalic controller had a period of 45 seconds for PWM control and the 'axe is working at 3 seconds with a slow pwm output.
Companies like Omron and Finder make the sort of relay you need.
A bit of a quick search is all you need do. Have to know who the suppliers are near you in the US when I am half way around the world (and down under)
but here is a start after a couple of minutes:
http://www.omron.com/ecb/products/pry/121/g5q.html
has relays with 5Vdc and 9Vdc coils and 125Vac contacts rated 10 Amps.
At 5Vdc the coil current is 40mA so you would need a transistor to interface between the PICAXE and the relay coil.
See PICAXE manual 3 page 23 for schematic on how to connect/drive a relay/solenoid coil
Andrew Cowan
One of the problems with SSR is that some have problems switching inductive loads. Relays do not - they are your best bet.
A
A
Andrew that is not entirely true. If you get a datasheet for any relay that gives full data you will find that the max switching current with an inductive load is less than with a resistive load. Reducing the relay contact current rating is the method of overcoming the "problems".
Andrew Cowan
I was basing my comment on a datasheet that said 'not recommended for use with inductive loads' (as far as I remember). I'll see if I can dig it out.
A
The other potential problem with zero crossing type SSRs is that they can sometime fail to turn off with very reactive loads.
kevrus
Relay/contactor contacts often have two current ratings...
These are...
AC1 which is primarily used for resistive loads (i.e. heating elements)
AC3 which is a lower rating to be used for inductive loads (i.e. motors)
Peter M
interesting comments... I did read that they are not recommended for inductive loads somewhere too.:confused:
But I thought I'd suck it and see....
10 months on. Running a water pump (600w induction motor from memory) directly from a picaxe. (inductive enough??)
interface couldn't be more simple, a wire from the bread board to the SSR.
Probably time it moved to a PCB, but lets not rush things!:D
