picaxehama0013
Hello,
I'm playing al little bit with the Blockly programming and was very impressed but now it looks like completely crashed...
I have worked with the Simulator funktion in Blockly. I was wondering why it had two simulation possibilities: One from PE6 itself and one in the programming window of Blockly, left near the Block Elements list. Both have worked perfectly until I've pressed the close "X" of the simulation in the programming window of Blockly. I was not be able to bring back this simulation window. Did you have any idea what I can do?
I have tried out many settings in option and configuration. Now Blockly will not work, at all. Always a text with "The host name could not be resolved." appears, if I try to load an existing Blockly program or want to open a new one. I've tried to set back all changed values in options and settings without success. I've re-installed the complete PE6 without success - now I'm at the end and hope you'll help or give some support...
Thanks!
Thanks!
