robbyraven
Hi everyone,
I'm trying to interface the AXE 033 LCD with my 18X project board.
I've put a jumper across J2 so I can use the same 4.5V as the project board.
When I apply power and short the CLK terminals, I get
serial/ i2c lcd
00/00/00 00:00
which is correct I think. However, when trying the sample program from the datasheet (yes, after removing the CLK jumper), I get either nothing, or just
00/00/00 00:00
The datasheet says I have to work directly from the picaxe pin, not the buffered outlet from the project board. How do I do this? So far I have been pressing the end of a bar wire against the exposed section of the relevant pin according to the pinout diagram (i.e. top right for serout 7, bottom right for serout 0).
Just to be clear, when I check the display with the CLK jumper, it's fine. I then, remove power, remove CLK jumper. Re-apply power, blank screen. Touch the wire from 'in' on the LCD module to output 0 or 7 (I've tried both, adjusting the sample program code accordingly), and I get either nothing or all those zeros. Press reset, on the project board to restart the program whilst the output is already in place, no difference, I just get blank screen or zeros.
Help?
serial/ i2c lcd
00/00/00 00:00
00/00/00 00:00
Help?
