Looked in "axe001 programmer.pdf" page 2 and it says " click file ...new template to open a new template"
When I do i am presented with 3 ...all with programs already written in them and all with .bas extension.
If I expand "file type" at the bottom to "all" then another 6 appear with chip numbers and asm extension.
Question is,
do I have to find out which chip is now used for the picaxe , say 08m2, and then select this particular asm template..??
I opened p12f629 and it has some detail already included so do I have to put assembler code in where it says "main" and leave everything as is...??
Not very clear in instructions unless I need to get info somewhere else.
OK..just copied and pasted an asm code in where it says, but then go to change to hex and it says filename must not be longet than 62 characters. I only have 3.
Next attempt was to remove the existing program and copy and paste my asm code there. Hit Picmicro ...assemble....then it says success.....do you want to program chip now......if yes...it says error...file not found ...if No...then nothing...no save as..nothing.
tried to put the code in here but forum says code is tooo long over 1000 characters
Question is,
