Andrew Cowan
The 7106 IC (A/D convertor) is the core of most cheap digital multimeters. The two factors that make it so useful are:
1 - Very low input current needed for a A/D reading (ie high input impedance).
2 - A VERY high maximum voltage allowed on input pins. The datasheet states Input voltages may exceed the supply voltages provided the input current is limited to ±100μA, but offers no further details. This means that you can measure a 1000v DC signal with the multimeter on the 1000:1 divider, but using the 200mV setting (no divider) will not damage the multimeter due to the high voltage allowed.
Creating a PICAXEd solution for the flexibility of measuring voltages
While the PICAXE can accept high voltages while current is limited, it does not have a very low input imedance. This means some kind of external buffer is needed. An op-amp is the usual answer. However, I haven't been able to find any op-amps with a high maximum input voltage.
My answer
My thought would be to use a 1:1 op-amp to buffer the signal, into a PICAXE ADC port. Under normal conditions, the input voltage to the op-amp would not be above the op-amps maximum. However, when the voltage does go above (wrong mode selected), a MOV rated at 12v or so would switch on, keeping the voltage low. The PICAXE would detect the voltage was at the MOV's trip voltage, and indicate the wrong mode was selected. Obviously there would be a resistor to limit the current flow to the MOV.
Would this setup work or have any problems (eg voltage loss)? The lowest rated MOV I have found is 12v.
I'd be interested in any thoughts.
Andrew
My answer
Andrew
