Aries
From time to time I write small routines used in many different projects. The routines often use spare system variables S_W0, etc, to avoid corrupting any variables in use within the calling program.
The manual explicitly states that S_W2 is adcsetup2 only for the 28X2. However, I have found that it applies to the 40X2 as well. It manifested itself in a curious way, when hspi didn't work sometimes. I narrowed it down, finally, to a question of whether an odd or even number of bytes was being retrieved. Here is the code:
This is the result:
The odd number of bytes (it doesn't matter how many) always returns zeroes.
The reason turned out to be that S_W2 is being interpreted as adcsetup2, and bit0 is ADC16 which on the 40X2 is C.4, which is the hspi SDI pin. So, apparently, when ADC16 is set to be ADC rather than logic, it is always zero, and so hspiin retrieves zeroes every time.
I think the manual needs correcting.
#no_data
#no_table
' symbols for interfacing with Microchip LC23/LC25 SPI-based chips
symbol Lc23Read = 0x03
symbol Lc23Write = 0x02
symbol EnableDisplayMemory = A.2 ' 25LC640
#macro ReadFromChip(ChipLocation,Bytes)
S_W1 = ChipLocation
S_W2 = Bytes
gosub ReadChipData
#endmacro
#terminal 76800
setfreq em64
pause 40000
hspisetup off
hspisetup spimode11e,spimedium
ptr = 0
ReadFromChip(0,10)
ReadFromChip(0,11)
ReadFromChip(0,12)
end
ReadChipData:
S_W0 = w0
w0 = S_W1
sertxd(13,10,"Read ",#S_W2," bytes from location ",#w0,":")
low EnableDefinitionMemory ' select chip
hspiout (Lc23Read,b1,b0)
for w0 = 1 to S_W2
hspiin (@ptr)
sertxd(",",#@ptrinc)
next w0
input EnableDefinitionMemory ' terminate operation
w0 = S_W0
Read 10 bytes from location 0:,85,78,75,78,79,87,78,32,83,79
Read 11 bytes from location 0:,0,0,0,0,0,0,0,0,0,0,0
Read 12 bytes from location 0:,85,78,75,78,79,87,78,32,83,79,85,82
