Hi Guys.
Just a quick question.
I am looking to put together a serial servo controller board. Ideally it would control 8 servos and multiple modules can be run from the same serial commnication comming from my master PICAXE. Each module would have jumpers to select the starting address of the servos
I intend to use HSERIN to recieve the data because as I understand software serial interferes with the SERVO command.
Am I correct in saying that on a 20X2 i can only control 7 servos if i am also using HSERIN due to pin conflicts? Is there a SIMPLE way round this?
Thanks
Darosu
Thanks
Darosu
