Hello Forum !!
Once again I turn to the forum for help.
In advance thank you for your time and support.
Here is my scenario:
I want to use 2 servos, each move independent from each other from the same 28x1. I will be using an analog stick for input. "Yes" I have read the manual several times for diagrams and power connections.
I don't have a wiring diagram yet.
all I have is the code, I have tested but it fails. when I simulate the code second servo don't move or at least that's what I see on the simulator.
Also if this was to work will there be a delay in commands when both servos are needed to move at the same time?
Once again thanks for the Help !
