Craftybytes
3 x questions:
1. Is the 'basic' (.bas) prog used in the Picaxe Datalogger (AXE110) availabe as a separate .bas file.?
2. Is the Datalogger "mission data download" (.bas) file also available as a separate .bas file.?
The reason is that I'm in the process of designing a small 'datalogger' that because of the number of extra i/o pins needed and the need for a larger memory points to me using the new 28X1 chip - so would like to port (and suitably modify) the existing .bas datalogger progs for the AXE110 unit to the 28X1..
3. In the existing AXE110 setup - how does the 'datalink' part of the "datalogger" (.bas) prog work.?
The reason I ask is that in the AXE110 - there is only the 'serial in' & 'serial out' lines used for the "datalink" - (NOTE: the 'datalink' is a separate set of i/o to that of the 'programming link') - no other 'handshake' signals are used - in my project I may need to use the 'CTS' handshake signal as a means of generating an "interrupt" to the 28X1 chip from the computer to 'upload' logged data for analysis..
Any comments or suggestions much appreciated..
TIA.
crafty.
3 x questions:
TIA.
crafty.
