1. As ICs shrink in size and increase in complexity, the tiny IC level traces get closer together and the voltage stresses are able to bridge the gaps or punch through the insulation. Likewise with surface mount components - conductive dirt on the boards starts to get critical - and miniaturization is one of the goals of design - saves space, power and money while improving performance.
2. Mosfets working at low voltage need a thin insulating gates. So if they made them for HV applications they wouldn't work over low voltages.
3. IC logic is traditionally 5 volts since it CONSUMES LESS POWER, produces less heat, and is now a standard. New designs are moving to 3.3 and 1.6 volts.
The 555 is very old technology. c.'70's
