This may be covered someplace, but I haven't found it yet.
Ok, I am on the next phase of my life-sized RC boat project. This is my first adventure into RC with PICAXE chips. What I'm going to do is use (temporarily, for tests only!!!) an aircraft radio set I already have to get the basic code worked out, then adjust it for a ground-lega radio to be named later. The problem I'm having is that I'm getting VERY different values for PULSIN on the 08M and the 28X2. Both are running at the same clock speed (default 4mhz). Can anyone shed any light, or do I need to post more detail? Its not a connection issue since both chips are reading every stick position within the upper and lower limits of the stick movements.
