🛸 Conway's Game of Life (Revisited 2026) - 👽 Mars Edition - PICAXE 08M2 MAX7219 V2c
radiosparks
Well-known member
It's about the code. This forum is long lived and is a great resource for just about anything you could dream up. Seems like all the fun has already been created. I just wanted to add my version of fun coding.
Recently featured on Codepen's "SPARK" 🌎was a themed collection of various versions of Conway's Game of Life.
To find inspiration I searched the Forum and found a long, very old, thread of the "Masters" showing off their coding designs. The most advanced coding techniques from @PaulRB 🔗 by using parallelism via bitwise logic and created a fast 2-bit adder tree. Far too advanced for my old brain, but impressive to study.
[ Hardware Setup ] PICAXE + MAX7219
For fun, I put together my own version of Life … using the PICAXE 08M2 and a MAX7219 with a 8X8 Matrix display using my previous post of a bargraph setup.
[ Display Concept ] TORUS topology
The matrix display is set up as a TORUS which has a single surface with no edges or boundaries — you can travel along it forever without hitting an edge. This also allows the Life form patterns to interact with themselves and run over each other.
[ Rule Variation ] Simplified Life Rule Errors
A happy coding accident produced this alternate version of Life by simplifying the rules: 3 or 4 neighbors create Life; everything else Dies. On an 8×8 LED matrix this generates rich behavior — sometimes longer-running patterns, fewer stagnant ponds, and plenty of motion (think swirling loops, drifting blobs, and generally lively feel).
A small snippet of the Life logic is included below due to the forum’s file-size limits; the full program can be downloaded at the end of the post.
The original Conway rules are still in the code — simply REM the MARS line and un-REM the LIFE line to switch between them.
' ---[ Core Function ]---
Game_Of_Life:
    '// Do Bit-Flip for RAM cell array offsets
     read_Offset = read_Offset XOR %00001000
    write_Offset = read_Offset XOR %00001000
        numCells = 0
    for y = 0 to Cells      ; used as MAX7219 Digit/BYTE Register (Y)
        '// Calc Read_Buffer addresses for Row BYTE Offsets
        addressT = y + 255 // 8 + read_offset
        addressC = y + read_offset
        addressB = y + 1 // 8 + read_offset
        '// Peek/Poke Write_Buffer Current Cell address
        addressW = y + write_offset
        '// Set current BYTES for testBIT
        peek addressT, i
        peek addressC, j
        peek addressB, k
        for x = 0 to Cells
            countCELLS = 0
            '// IF:ELSE faster than SELECT:CASE
            if x = 0 then ; Handle edge wraparound Cells
                testBIT = i : countCELLS = bit31 + bit25 + bit24
                testBIT = j : countCELLS = countCELLS + bit31 + bit25
                cell_State = bit24
                testBIT = k : countCELLS = countCELLS + bit31 + bit25 + bit24
            else if x = 1 then
                testBIT = i : countCELLS = bit26 + bit25 + bit24
                testBIT = j : countCELLS = countCELLS + bit26 + bit24
                cell_State = bit25
                testBIT = k : countCELLS = countCELLS + bit26 + bit25 + bit24
            else if x = 2 then
                testBIT = i : countCELLS = bit27 + bit26 + bit25
                testBIT = j : countCELLS = countCELLS + bit27 + bit25
                cell_State = bit26
                testBIT = k : countCELLS = countCELLS + bit27 + bit26 + bit25
            else if x = 3 then
                testBIT = i : countCELLS = bit28 + bit27 + bit26
                testBIT = j : countCELLS = countCELLS + bit28 + bit26
                cell_State = bit27
                testBIT = k : countCELLS = countCELLS + bit28 + bit27 + bit26
            else if x = 4 then
                testBIT = i : countCELLS = bit29 + bit28 + bit27
                testBIT = j : countCELLS = countCELLS + bit29 + bit27
                cell_State = bit28
                testBIT = k : countCELLS = countCELLS + bit29 + bit28 + bit27
            else if x = 5 then
                testBIT = i : countCELLS = bit30 + bit29 + bit28
                testBIT = j : countCELLS = countCELLS + bit30 + bit28
                cell_State = bit29
                testBIT = k : countCELLS = countCELLS + bit30 + bit29 + bit28
            else if x = 6 then
                testBIT = i : countCELLS = bit31 + bit30 + bit29
                testBIT = j : countCELLS = countCELLS + bit31 + bit29
                cell_State = bit30
                testBIT = k : countCELLS = countCELLS + bit31 + bit30 + bit29
            else if x = 7 then ; Handle edge wraparound Cells
                testBIT = i : countCELLS = bit31 + bit30 + bit24
                testBIT = j : countCELLS = countCELLS + bit30 + bit24
                cell_State = bit31
                testBIT = k : countCELLS = countCELLS + bit31 + bit30 + bit24
            end if
            '// Once the code above finishes we find out if the test Cell lives or dies
            read x, BITmask ; fast bit mask lookup for test Cell
            '// Write Buffer Cell State
            peek addressW, result
        '// Life on MARS!
            if countCELLS = 3 or countCELLS = 4 then
        '// Conway's Game of Life Rules
            'if countCELLS = 3 or cell_State <> 0 and countCELLS = 2 then
                'cell_State = 1 ; "It's alive! Boris"
                result = result or BITmask
                inc numCells
                'cell_State = 0 ; always DEAD
                result = result andnot BITmask
            '// Store result in Write Buffer
            poke addressW, result
        next x
    next y
    inc Generations
    '// Seed Random 4X4 Cell Area if still life or oscillator running too long
    if Generations > 31 or numCells < 5 then
        'call Preset_Life
        call random_GEN
        'call show_Life
        'pause 5000
        Generations = 0
    end if
[ Adding Entropy with Light ]
One challenge with microcontrollers like the PICAXE is that their random number generators aren’t truly random. To inject a bit of unpredictability, I added my Ambient Light Sensor (see my post 🔗).
Depending on the light levels in the room, the sensor feeds entropy into the system and seeds the random number generator with a fresh start value. This makes each generation of Life feel unique and creates a continuous action. Although, a lot of patterns will still repeat.
[ VIDEO ]
The video demonstrates version 2b of the project. Version 2c, described above, includes speed improvements and runs the patterns more smoothly.
[ Links & Resources ] Code and Life References
I won't go into a long tutorial of how it works, see references below will give you plenty of rabbit holes to explore.
Conway's Game of Life, has anyone done it with a PICAXE? 🌎
Wikipedia Description of Conway's Game of Life: 🌎
Rosettacode.org 🌎 contains almost every version of code for any level of computer language. Very interesting to see all the other ways people have coded this simple function.
Rosettacode Game of Life Variations: 🌎
Smallest Physical Implementation of Conway's Game of Life... Probably? Utilizes a Microchip PIC10F320 📖 microcontroller in a 6-pin SOT-23 package! Written in assembly code (source available) and generates it's own analog video signal. A must read!
Worlds Smallest Life: 🌎
Universal Engineering Meme : "Can it play DOOM?"
[ VIDEO ] UPDATED 20260120
The video demonstrates Version 2c of the code described above, includes speed improvements and runs the patterns more smoothly. No, the video has not been changed in speed, the code is really faster.
Back
