I made this program a little while ago, but recently put the serial port interface on it. What it is, is a PC based PICAXE LCD screen, that the user can enter commands on the screen on connect to a PICAXE in the normal way, and will accept all the commands used by a normal LCD screen.
The easiest way to use it with a PICAXE is by using the SERTXD command on the PICAXE, and make sure to set the baud rate on the program to 4800 in the options menu (it is by default)
In addition to the normal 254,192,"Hello" command, the following standard commands are also acceptable:
254,...
1 Clear Screen
4 Right To Left
6 Left To Right
12 Disable Cursor
13 Enable Cursor
16 Move Cursor Back
20 Move Cursor Forward
as well as custom characters
There box on the program to enter a command to test and see what it will to. An example of an accepted line is: 254,192,"Hello",#b1 The program will ask for the value of b1, and display the result on the screen.
DOWNLOAD
Let me know how well it works, and if any commands you try dont work proberly
Ive also attached some screenshots
Matt
254,...
1 Clear Screen
4 Right To Left
6 Left To Right
12 Disable Cursor
13 Enable Cursor
16 Move Cursor Back
DOWNLOAD
Matt
