Im getting a bit confused with the datasheet for the 28X PIC16f872
Provided I use a suitable resistor to tie the input pins to 0v can I then use a 1.5V input logic?
Or should I seriously be considering using transistors to step the 1.5V logic up to 5V?
Is it possible to step up the voltage with some form or reverse potential divider trickery?
