Hi Dr.
I've got a 433mg RX module hooked up to a 40X1. Im using the serin time out com. Problem is the serin timeout never times out because the 40X1 sees all the noise on the serin line comming out of the rx unit as a signal i.e. valid incooming data.
I've tried a 47UF electro cap, that smooths out the singal enough to let the time out work properly, problem is though it so smooths out the signal that it wont respond to valid incomming data txd by the tx 433mg unit. Any suggestions on how to get around this?
Â
Â
