kranenborg
Hello,
In a previous discussion on a picaxe-controlled receiver (<A href='http://www.rev-ed.co.uk/picaxe/forum/Topic.asp?topic_id=6699&forum_id=30&Topic_Title=RF%2BProject%2BIdea%2B%252D%2Bsuggestions%253F&forum_title=No+new+posts+please%21+22 ' Target=_Blank>External Web Link</a> ) I shortly mentioned that I have a long-term plan for the design of a general coverage receiver (150 KHz - 30MHz). Although I probably will start next year at the earliest (first some other projects have to be finished, notably the "SerialPower" network concept) and the project takes a few years to complete, I have already the general concept in my mind. As a few forum members indicated similar plans, I thought it would be nice to start a discussion here on such a design and see were the main challenges are.
My final, "ideal" goal is the following type of receiver:
- Double-Conversion Superhet
- Receiving range 150KHz - 30MHz (LW, MW, SW)
- Receiving modes AM, SSB, FM, DRM
- selectable IF bandwidths (PICAXE controlled)
- SA602A first mixer at 10.7MHz first IF
- TDA1572 (or TDA1072A) amplifier, second mixer + detector at 455KHz (single-chip AM circuit)
- PICAXE-controlled DDS circuit for receiver freq. oscillator
- PICAXE-tuned preselector stage
- PICAXE-controlled RF pre-amplifier (amplification control dependent of frequency and time!)
- Extreme user friendliness using PICAXE control circuit (fully automatic + full manual modes)
- Possibility to download and directly use SW broadcast schemes from internet
- Single PICAXE used (PICAXE-28X1)
This is a very challenging design, I am not a RF specialist (although I have some prototyping experience, see <A href='http://www.kranenborg.org/ee/ee2.htm ' Target=_Blank>External Web Link</a> ) and the risk of not arriving at the final stage is large, I want to stucture the design process in such a way that always some result is obtained:
- A simple design from the start (single-conversion superhet, functional even without a picaxe)
- Each incremental stage tested to give a better receiver (so that it is not a waste of time/money if one gets stuck at a certain level).
- Use of readily designed PCB project boards for RF part (Elektor).
- Use experiences from existing designs as much as possible (4 Elektor/Elektuur designs from Gert Baars)
So what are the main challenges, and how does the picaxe get involved?
A: DDS application for frequency generation:
A DDS provides a lot of potential for direct frequency control, and I plan to use the AMQRP DDS-60 kit (<A href='http://www.amqrp.org/kits/dds60/ ' Target=_Blank>External Web Link</a> ) as this seems to me the only one that can be practically built and used. It can be interfaced via spi directly to a PICAXE, the latter generating the tuning word.
B: Preselector:
The AD9851 DDS of the DDS-60 kit uses a 10-bit DAC (14-bit would have been much better) which implies that a lot of spurs (different frequencies at non-negligible amplitudes, typically -50 - -70dB of the main signal) are generated. Due to this the receiver gets tuned to several frequencies at the same time, causing an unacceptable quality degradation.
To solve this problem I opt for a very andvanced preselector and subsequent pre-amplification stage between antenna and first mixer. This is clearly the most important stage!
* 8-band preselector consisting of:
- - a double AM varicap
- - switchable coils (using mini-relais) to select each band
* tuning of the preselector:
- - 256 steps per band via DS1803 digital pot
- - each step is calculated via a 4th-order polynomial approximation
- - approximation is calculated on the fly during tuning using a uM-FPU
- - approximation polynomial is calculated using a PC and a measurement procedure
* double-gate mosfet as RF amplifier:
- - gate voltage controlled via DS1803 pot
The automated tuning of the preselector is complicated and requires a one-time manual initialization, but seems still feasible, i have worked out some ideas on how to do it.
C: Automatic Selection of IF bandwith (PICAXE controlled)
D: Control issues
There are a lot of control issues, solved on the hardware level via I2C & SPI communications as
follows:
* PICAXE DDS Frequency tuning word generation and communication via SPI
* Preselector band selection + tuning (see also item B above):
- - 8-band selection via MCP23008 I/O expander (I2C) and minirelais
- - tuning via DS1803 (1/2) and varicap
- - DS1803 control via interpolating polynomial evaluation via uM-FPU
* RF-amplifier via BF961 Mosfet and DS1803 (1/2) digital pot
* IF bandwidth selection via MCP23008 and PIN diodes
* Frequency display using 6*7-seg display controlled via MAX6955 (i2c)
* Separate LCD display for program information and control info display (i2c)
* EEPROM storage of configuration settings and program information (i2c)
* DS1337 clock (i2c) for program calender and RF amplifier control
It is very important to start simple and have a strategy for extending and testing, and I would propose something like the following sequence:
1) Start with a simple non-digital version for a AM radio circuit:
- 500 - 1800 KHz
- single-conversion superhet
- tuning of antenna circuit and oscillator using AM-varicaps
2) Replace oscillator circuit with DDS VFO and lCD circuit
- DDS is picaxe controlled via SPI
- LCD display for frequency display
- frequency change using potentiometer at PICAXE adc input
3) Add preselector and RF amplifier
4) Add 7-seg frequency display
5) Add IF band selection
6) Add PC - receiver interface for downloading of SW transmission schemes
I can add some more information on the various stages, but many details are still open to discussion and still unclear to me. Some other forum members with similar ideas?
Well, who wants to jump on the train?
Even issues on a simpler, limited design (direct conversion) may be discussed here as well
Regards,
Jurjen
http://www.kranenborg.org/ee/picaxe
Edited by - kranenborg on 15/05/2007 21:37:05
B: Preselector:
D: Control issues
follows:
- 500 - 1800 KHz
Regards,
Jurjen
