No!
Unless you want to risk your PICAXE.
Often when NFETs fail, they fail to a shorted condition from drain (positive supply) to gate.
Which means that your poor little PICAXE will attempt to sink the current that can be developed by the positive supply. Usually this is a tad more than PICAXE can handle.
A current limiting resistor is needed to protect the PICAXE in the event this happens.
The NFET will run a little cooler if you parallel a ceramic cap to the current limiting resistor.
While blocking DC the cap will apply the leading edge of a signal to the gate which reduces the time the NFET is exposed to a transitional state between shutoff and turned on with heavy loads.
This will preserve the switching speed.
Edited by - desulfator on 21/11/2006 23:00:48
