I can't see why you're fascinated with verticals for 433MHz use, since at this UHF frequency directional antenna are compact & a breeze to make!<A href='http://www.picaxe.orcon.net.nz/yagi433.jpg' Target=_Blank>External Web Link</a> Although praised for VHF omnidirectional work, 5/8 whips just have lower angle radiation & "waste" your modest tx output by radiating it in all directions -when receiving they'll also pick up unwanted interference. Most of these 433MHz Tx are 5-10mW & as ISM regs. allow 25mW ERIP then a boosting Yagi style antenna is legal & far preferred if point to point. You could even use a parabola, although it'd have to be large (~1m) since a 70cm wavelength! UHF signals punch thru' modest wooden/plaster walls OK, so is there any blocking metal in yours? Maybe other ISM devices nearby -garage door openers etc?
Typically simple breadboarded DS18B20/08M setups yield ranges to 50m (doubled with cotanga Yagi) in NZ suburbs. A simple "store & forward " repeater gets around dead spots & gave 200m even with simple 1/4 wave whips => www.picaxe.orcon.net.nz/433rpt.jpg <A href='http://www.picaxe.orcon.net.nz/433rpt.jpg ' Target=_Blank>External Web Link</a>. The "rubber duckie" antenna on the Tx shown in fact came inbuilt, & worked a treat. These units were only ~£2 each from a NZ schools supplier as well!
Elevated cotanga Yagis both ends can push ranges to ~1km. Perhaps solar power the repeater? If at all possible borrow a UHF scanner with a signal strength meter to assist in antenna tweaking & positioning. Naturally <b> s l o w </b> the data rate (300bps?)if signals are weak.
A very important range issue is that some of these cheapie 433 units have deaf receivers! READ THEIR SPECS! The Maplin Rx seems a puny -90dBm RF sensitivity, meaning only strong nearby signals will be heard. I've worked with many 433 offerings & some are much more sensitive than others. Tx output varies too. Many Rx modules are VERY picky about the supply voltage range, typically only working with 4.5-5.5V. The usual Picaxe 4.5V is hence marginal, with 4 x NiCds (4.8V) better.
I penned several Silicon Chip articles (Dec.05/Jan.06) covering 433/08M applications. These concentrated on Jaycar's KeyMark offering (RXB1)<A href='http://www.jaycar.co.nz/products_uploaded/ZW3102(mod).pdf ' Target=_Blank>External Web Link</a>which, although more costly (~£4), has a superior -104dBi Rx sensitivity. Even that is puny beside some (Chipcon etc ~-120dBi) which can work over miles. Every 6dB gain is equiv. to range doubling, so hence 18dB system gain yields 2x2x2 =8 times the range. Article teasers =><A href='http://www.siliconchip.com.au/cms/A_105581/article.html' Target=_Blank>External Web Link</a> and <A href='http://www.siliconchip.com.au/cms/A_105744/article.html ' Target=_Blank>External Web Link</a>
Stan-ham since 1966(ZL2AJZ), back when antenna (3.5MHz)were the size of trees...
Edited by - stan. swan on 25/05/2006 00:19:49
