Hello,
After following the brilliant advice I received on minimizing interference, I made a tragic discovery. My hall effect sensor no longer detected anything once I switched the cable from unshielded extension cord to shielded 12core data cable. I suspect it never was detecting anything, and that the pulses I previously received were purely induction in the wire.
Therefore I need a new reliable way to detect ignition pulses. Is there a better way to make an induction pickup? I hear winding a piece of wire around the HT lead, and then putting diodes across the ends in the hope that that would limit the voltage across them to 0.6v. Does that sound practical? What specifically would be needed in terms of isolation etc?
Cheers
Ben
Cheers
Ben
