I haven't been following this forum, but someone on the Yahoo forum said you were looking for a solution to a problem that I had just solved. I developed and tested a circuit (picaxe 08M) that: a momentary PB turns on the Picaxe, the picaxe turns on a 2n3904, the transistor turns on a P-channel MOSFET, and the MOSFET maintains power to the Picaxe. In my case a second push on the PB shuts the circuit to zero current draw. Or you could have the Picaxe shut itself down at the end of a process. I don't know if there is a place to post files and images here, but they are in the FILES section of the Yahoo forum under a folder: "Servo vs Pulse Problem" or just use: http://groups.yahoo.com/group/picaxe/files/Servo%20vs%20Pulse%20Problem/
