Also very confused!
Hi there
This is my first post on Timers, but after the bet possible option for taking timings in ms, is this possible in a simple way?
Also could someone enlighten me how to start a new thread on this and my apologies for posting in the wrong place if I am.
I have read the site and come across many different way of timing, Timer, settimer, Timer 3, external crystals, ect. .
I have the 28x2 5V modules.
I am not a complete beginner with picaxe as I have has a play around with remote control driving radio modules and everything worked like a dream after a lot of trial and errors.
What I am after is to take timings in ms over a max period of 6 seconds for a project I am working on.
I wish the timings to be consecutive
so example
PIN high. .. ..start timing and toggle pin back
T1=2123ms ' max timing for any timings I will be taking is 6000ms
Pin high again, stop T1, start T2
T2=1343ms
Pin high again, stop T2, start T3
T3=3421ms
Pin high again, Stop T3
Then I wish to do some maths operations on the variables T1,T2,T3
After I wish to generate some pulses of a predetermined length in ms
I believe that this is extremely simple using the pause statement. The length of the pulses would be between 100 to 1200 ms
so if I use for example
PAUSE 1285
then PIN5 high
pause 10
PIN5 Low
I would have a time period of 1.285 seconds, then a pulse for 10ms , am I correct?
If so, then why could the pause statement if so accurate be used as a timer for counting?
you know
do a=a+1
pause 1 ' would this not time 1ms
until pin 5 high ' press pin 5
debug pin5
for example?
I am totally confused as to why its so difficult to make a ms second timer?
any enlightening information would be much appreciated, and I have trawled the site and come across many different options and many different problems.
I know about the Major and Minor ticks, is this the best option?
So my parameters again or to take consec timings in ms no more than 6000 max
do some maths ( I can deal with that bit)
then pulse out a set pulse no more than 1200 ms say 3 times.
I don't expect anyone to do this for me, but after several months going over the board, and the documentation I am either thick and its staring me in the face, or its more complicated that i first assumed.
In return anyone wanting help with the infra red or radio modules linked to 08m, i have some code that works and links to modules that work.
I think that the Picaxes are amazing and really cool, programed only in basic before and C.
Regards
Marc
Als
Hi there
so example
T2=1343ms
T3=3421ms
PAUSE 1285
then PIN5 high
pause 10
PIN5 Low
you know
do a=a+1
debug pin5
for example?
Regards
Marc
Als
