Absolute_Beginner
OK So I'm probably not using the PE's Terminal for it's proper purpose...I'm presently (temporarily I hope) using it to check the contents of my 24LC16B EEPROM so I'm inspecting a few kbytes of data sent by sertxd.
When I try to send more than a certain amount (it varies, I'm not sure why because I'm always sending the same number of bytes [numerical values and sonstant length strings, i.e. white spaces] the number of numbers retained in the I/P of the terminal (or copied if I use the copy I/P buffer option) is truncated and I lose the first however many data bytes (several hundred bytes).
If I write 6 bytes per line through 2048 lines (about 12K) I lose the ~ the first 1400 lines or so. (The way I overcame this problem, a temporary fix, was to modify my code each time and run it three times, collecting about 1/3 at once; in fact the I/P buffer seems to hold the first 1000 lnes without any problem...).
I assume this is me trying to load too much data into the I/P buffer of the Terminal...if so, what the size of this buffer ? I can't find it in parts 1&2 of manual (although it mifght be there !) nor have I looked in absolutely every post in the forum.
Mght be useful for some folks if someone knows the size of O/P buffer too.
AB
24.June.2011
PS code available if needed
AB
24.June.2011
