Dear all, I took out the IR-camera from a Wii-mote remote control and used it to build the stand-alone camera that was made by "robotfreak", seehttp://letsmakerobots.com/node/7752
The reason: this would be the long sought-for solution for our robot location problem: the camera on the ceiling and an IR-led on the robot would do the trick!
I know the camera address and I used I2C protocolls to read out the camera, and I get the impression that in principle there is some contact between the camera and the picaxe. (Protocolls used: READI2C (variable,...) and READI2C location,(variable,...). Both protocolls give at least som coherent rows of numbers. However: waving an IR-led or a candle in front of the camera does not change the numbers (this should be the case).
My question now is the following: before diving into the details of the I2C protocolls used: it would seem that the camera needs some initiation (through writeI2C). This is also suggested on Robotfreak's website (see wii_remote_ir_sensor_sample.pde at his website). But the problem is: I tried that but it does not at all change the readout of the camera. So briefly: has any member of this forum experience with the readout of this Wii-mote camera?
Thanks very much in advance for your reaction.
Ronald
Ronald
