This works for me (YMMV):
'* Symbols ************************************************
symbol LcdSE = c.6
symbol LcdRS = c.7
symbol LcdByte = b1
'* Main Routine *******************************************
gosub LCD_Init
'send ABC...NOP to LCD
for LcdByte = 65 to 80
gosub LCD_WrChr
next LcdByte
gosub LCD_Line2
'send 012...DEF to LCD
for LcdByte = 48 to 57
gosub LCD_WrChr
next LcdByte
for LcdByte = 65 to 70
gosub LCD_WrChr
next LcdByte
end
'* Initialise LCD *****************************************
LCD_Init:
'set relevant pins to output
dirsb = %00001111
dirsc = %11000000
'wait for LCD to stabilise (>40ms after Vcc > 2.7V)
pause 200
'send 0011 three times to initialise LCD by instruction
outpinsb = %00000011
pulsout c.6,1
pause 10
pulsout c.6,1
pause 1
pulsout c.6,1
pause 1
'send 0010 to set interface to 4-bit
outpinsb = %00000010
pulsout c.6,10
pause 1
'interface is now 4-bit, we can use the LCD_WrIns routine
'Function Set ... 0 0 1 DL N F - -
LcdByte = %00101000 'DL = 0, 4-bit: N = 1, 2 lines: F = 0, 5x8 font
gosub LCD_WrIns
'Display Control ... 0 0 0 0 1 D C B
LcdByte = %00001000 'D = 1, disp off: C = cursor off
gosub LCD_WrIns
LcdByte = %00001100 'D = 1, disp on: C = cursor off
gosub LCD_WrIns
gosub LCD_Clear
'Entry Mode ... 0 0 0 0 0 1 I/D S
LcdByte = %00000110 'I/D = 1, increment: S = 0, no display shift
gosub LCD_WrIns
'* Display Character On LCD *******************************
LCD_WrChr:
'set RS high (write data)
high LcdRS
'send high nibble by shifting it to the low nibble of port B
outpinsb = LcdByte / 16
pulsout LcdSE,10
'send low nibble by masking it onto port B
outpinsb = LcdByte & %00001111
pulsout LcdSE,10
'* Send Instruction to LCD ********************************
LCD_WrIns:
'set RS low (issue command)
low LcdRS
pulsout LcdSE,10
pulsout LcdSE,10
'* Clear LCD **********************************************
LCD_Clear:
LcdByte = 1
gosub LCD_WrIns
'* Move To Line 1 *****************************************
LCD_Line1:
LcdByte = 128
gosub LCD_WrIns
'* Move To Line 2 *****************************************
LCD_Line2:
LcdByte = 192
gosub LCD_WrIns
