First thanks for making the cool 18M2, just what i need for some projekts
PICAXE181 Touch Sensor Demo
I got this test board and it is working well, but just one thing missing that maybe will be a good idea if you some day need to change it.
A small potmeter on a ADC input so you better can play with fine tuning the sensetive of the touch..... just a idea.
And for sharing here is my code for the PICAXE181 board and it is self calibrating each touch pad at startup and seem to work well.
Tooms
; ***** Sample Header File *****
; Filename: PICAXE181_selfcalib_touch_1.bas
; Date: Today
; File Version: 0.0.0.1.beta
; Written by: Tooms
; Function: selfcalib touch 1
; Last Revision: This one
; Target PICAXE: 18M2
Init:
'Set all led high
high B.4
high B.5
high B.6
high B.7
'Calc baseline for C.0 to W10
for B18 = 1 to 20
touch16 C.0, W8
Let W10 = W8 / 20 + W10
next
LOW B.4
'Calc baseline for C.1 to W11
for B18 = 1 to 20
touch16 C.1, W8
Let W11 = W8 / 20 + W11
next
LOW B.5
'Calc baseline for C.2 to W12
for B18 = 1 to 20
touch16 C.2, W8
Let W12 = W8 / 20 + W12
next
LOW B.6
'Calc baseline for B.3 to W13
for B18 = 1 to 20
touch16 B.3, W8
Let W13 = W8 / 20 + W13
next
LOW B.7
'set detect value based on baseline + add-value
'The last value in each line controlle how sensetive it is and 500 seem good value
Let W10 = W10 + 500
Let W11 = W11 + 500
Let W12 = W12 + 500
Let W13 = W13 + 500
Main:
'Touch C.0
touch16 C.0, W0
if W0 > W10 then
high B.4
Low B.4
end if
'Touch C.1
touch16 C.1, W1
if W1 > W11 then
high B.5
Low B.5
end if
'Touch C.2
touch16 C.2, W2
if W2 > W12 then
high B.6
Low B.6
end if
'Touch B.3
touch16 B.3, W3
if W3 > W13 then
high B.7
Low B.7
end if
'Debug
'pause 500
Tooms
